NI USB-6251
I have an NI USB - 6251 and I'm trying to drive it with VB 6. I have tried the sample code installed when installing the latest driver but this cannot find the unit. The test software works ok so I assume the unit is ok. I've also tried the C++ sample and this failed with the same error it also gave a status code: -201003. Is this software suitable for use with a USB device?
(3,207 Views)
Hi
Problem solved , the physical channel allocated in the software was wrong. the channel is Dev3/ai0:1 not as sample Dev1/ai0:1.
davetech
(3,197 Views)
