NI USB-6255 Linux Support
Will there ever be a linux driver for the NI USB-6255?
Our group uses several of these for testing purposes, but would like to migrate away from Windows.
(5,650 Views)
Greetings,
Unfortunately, I won’t be able to say if there are future plans with this specific device but If you have one of the supported devices under Linux (as mentioned on this link: NI-DAQmx and NI-DAQ Driver Support: Portable Devices ) you can change your hardware.
Another possibility is to setup a Windows Virtual Machine since USB ports can be pick by the VM but I don’t think that would be your number 1 choice
Alejandro C. | National Instruments
(5,620 Views)
@alcava.cr wrote:
Greetings,
Unfortunately, I won’t be able to say if there are future plans with this specific device but If you have one of the supported devices under Linux (as mentioned on this link: NI-DAQmx and NI-DAQ Driver Support: Portable Devices) you can change your hardware.
Dont ever expect them to ever work reliably - proprietary kernel drivers are broken by design.
http://forums.ni.com/t5/Multifunction-DAQ/Linux-NIDAQmx-install-problem/m-p/3225670/highlight/false#...
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(4,144 Views)
