NI-USB 6259 How to disable Analog output- put in high impedabce mode
I want to connect AO to a device pin which can be input or active output. Can I disable the output when the device is sourcing voltage (and measure the signal with AI)?
(3,658 Views)
Hi Dimo,
I've had a look into this and from what I can find disabling the output will not switch it to a high impedance state. I think the best solution for this would be to connect a relay to one of the digital outputs and control whenever to disconnect the AO from your device when the device is sourcing.
Kind Regards,
Jas.W
Jason W.
National Instruments UK & Ireland
(3,630 Views)
I can confirm that the AO lines do not have a high impedance state.  Driving the lines externally can damage them.  Jason's recommendation of an external relay is probably the best route to take.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,623 Views)
Thanks Jason and Seth, will try relay or mux.
(3,618 Views)
