NI- USB 6351 DAQ Measuring between two single ended channels
Hello i have no differential Analog Inputs left.
Is it possible to measure differential between two single ended points?
Thank you in advance
Br Christian from Austria
(2,451 Views)
In that case, you don't have any Single Ended inputs either.  Look at the pinout.  AI8 is used as AI0- if AI0 is set to be differential.  So you don't have AI8 available since it is already being used.
What are you trying to measure?  How many channels do you need?
(2,435 Views)
