NI USB 6361 C programming
Hello. I have NI USB 6361 board and I want to write C program (I use Embarcadero C++ Builder) for acquiring analog data from this board (a0 channel). I connect signal generator to ao channel.
I read documentation and examples for my board. My program allows to acquire data, but I have one problem.
I can see waveform, but values of data are differs from data, that I acquired from board with Measurement Studio. I acquired data and export this to Excel, and find min and max values. Signal acquired with Measurement Studio have stable values for max and min. But my program give me different values and I dont know why.
Can anybody expect my C code and help me? I attached my code below. Excuse me for my Enlgish and thanks for help.
	float64		max,min,value;
	int32		points,written,error;
	char        errBuff[2048]={'\0'};
	char		*channel;
	wchar_t		*ch;
	int 		i=0;
	TVarRec 	args[1] = {0};
	max = StrToFloat(EditAOMaxValue->Text);
	if (max>10.0) {
		max = 10.0;
		EditAOMaxValue->Text = "10,0";
	min = StrToFloat(EditAOMinValue->Text);
	if (min<-10.0) {
		min = -10.0;
		EditAOMinValue->Text = "-10,0";
	value = StrToFloat(EditAOValue->Text);
	if (value>10.0) value = 10.0;
	if (value<-10.0) value = -10.0;
	args[0] = value;
	EditAOValue->Text = Format("%1.1f",args,0);
	points = StrToInt(EditAOPoints->Text);
	for(;i<points;i++)
		data[i] = value;
		//5.0*(double)i/points;
	ch =  ("Dev1/"+ ComboBoxAOChan->Items->Strings[ComboBoxAOChan->ItemIndex]).t_str();
	channel = AnsiString(ch).c_str();
	// DAQmx Configure Code
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
	DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,channel,"",min,max,DAQmx_Val_Volts,NULL));
	DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,points));
	// DAQmx Write Code
	DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,points,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL));
	// DAQmx Start Code
	DAQmxErrChk (DAQmxStartTask(taskHandle));
	// DAQmx Wait Code
	DAQmxErrChk (DAQmxWaitUntilTaskDone(taskHandle,10.0));
	args[0] = written;
	LblStatus->Caption = Sysutils::Format("Status: written %d points\n",args,0);
Error:
	if( taskHandle!=0 ) {
		// DAQmx Stop Code
		DAQmxStopTask(taskHandle);
		DAQmxClearTask(taskHandle);
	if( DAQmxFailed(error) ) {
		DAQmxGetExtendedErrorInfo(errBuff,2048);
		args[0] = errBuff;
		ShowMessage(Sysutils::Format("DAQmx Error: %s\n",args,0));
Message 1 of 8
(5,450 Views)
Hello Skyer,
Just so that I understand, does the exact some code give you different results between the two development environments?
Also, this code appears to only output values. How are you reading these values back in?
Message 2 of 8
(5,413 Views)
Hello OlliesCamel,
I'm sorry, but I posted the wrong code. Below my code for acquiring analog data in finite mode.
	float64		max,min;
	int32		points,mode,read,error;
	char*		channel;
	wchar_t		*ch;
	int 		i=0;
	char*		sample;
	char*		buf;
	fprintf(LogFile,"Calibtrating...\n");
	max = StrToFloat(EditAIMaxValue->Text);
	if (max>10.0) {
		max = 10.0;
		EditAIMaxValue->Text = "10,0";
	min = StrToFloat(EditAIMinValue->Text);
	if (min<-10.0) {
		min = -10.0;
		EditAIMinValue->Text = "-10,0";
	switch (ComboBoxAIMode->ItemIndex) {
		case 0:	mode = DAQmx_Val_Diff;
		case 1:  mode = DAQmx_Val_RSE;
		case 2:  mode = DAQmx_Val_NRSE;
		default: mode = DAQmx_Val_Cfg_Default;
	points = StrToInt(EditAIPoints->Text);
	ch =  ("Dev1/"+ ComboBoxAIChan->Items->Strings[ComboBoxAIChan->ItemIndex]).t_str();
	DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,channel,"",mode ,min,max,DAQmx_Val_Volts,NULL));
	DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",100000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,points));
	// DAQmx Start Code
	// DAQmx Read Code
	DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,points,10.0,DAQmx_Val_GroupByChannel,data,points,&read,NULL));
	max = -30.0;
	min = 30.0;
	args[0] = read;
	LblStatus->Caption = Sysutils::Format("Status: read %d points\n",args,0);
	for (i = 0; i < read; i++) {
		args[0] = data[i];
		Memo1->Lines->Add(IntToStr(i)+"  "+Format("%2.4f",args,0));
		sample = StrFmt(buf,"%2.4f \n",args,0);
		Series1->AddXY(i,data[i],"",clBlue);
		if (data[i]>max) { max = data[i];}
		if (data[i]<min) { min = data[i];}
	args[0] = max;
	LblMaxValue->Caption = "Max value = " + Format("%2.4f",args,0)+ " V";
	args[0] = min;
	LblMinValue->Caption = "Min value = " + Format("%2.4f",args,0)+ " V";
Error:
		// DAQmx Stop Code
		args[0] = errBuff;
	fclose (LogFile);
Message 3 of 8
(5,400 Views)
How do you know that the Measurement Studio values are the correct values?
Which language are you using with Measurement Studio?
Message 4 of 8
(5,379 Views)
Skyer,
Message 5 of 8
(5,373 Views)
1) No, I use single development enviroment - Embarcadero RAD Studio C++ Builder.
2) I connected waveform generator to board. And I know values from generator. Also I use oscilloscope to check the signal.
Message 6 of 8
(5,336 Views)
Maybe I'm missing something, but how are you using Measurement Studio, if you aren't using the Visual Studio IDE? Are we talking about the same product?: http://www.ni.com/mstudio/
Message 7 of 8
(5,309 Views)
You mentioned Measurement Studio in your first post.
Yet you now say you are using Embarcadero RAD Studio C++ Builder.
Which is right?
It seems you are confused.
Message 8 of 8
(5,298 Views)
