NI USB 6361 NOT TURN ON
my NI, when it is turned on, the led flashes and will not turn on. My desktop does not recognize the usb cable anymore, apparently it is off. Possibly it has received a voltage of 220V on an RSE signal cable or differential. Does the NI 6351 have any security features? Could it have spoiled if you received a voltage across a signal cable?
(2,135 Views)
Hi Guilherme,
The AI protection level of the 6361 is 25V(Device on) and 15V(device off). If you applied a voltage into analog inputs higher than those values, probably the device gets damaged. Below is the spec documents:
NI 6361 Specifications
http://www.ni.com/pdf/manuals/374650c.pdf
I recommend you to contact your regional NI local support.
Any question let me know.
(2,103 Views)
