NI and RealBasic
Greetings.
Does NI have (or plan to have) libraries which can be used with RealBASIC on Mac OS X similar to the NI Measurement Studio (which includes measurement tools for Microsoft Visual Basic 6.0, Visual Basic .NET, Visual C#, and Visual C++)?
This would be *very* helpful.
Thanks much.
(3,266 Views)
Hi gllec,
You can find information regarding NI-DAQ support for text-based programming on Mac in the following article:
Text-Based NI-DAQ Programming on Mac OS
Also, you should submit your idea at the following site as a product suggestion.
Feedback to NI
Lesley Y.
(3,236 Views)
@LYu wrote:
Hi gllec,
Feedback to NI
Lesley Y.
Does this actually work with OS X?
(3,226 Views)
Hi gllec,
For Mac OS X you will need to use the NI-DAQmxBase 1.4 driver for your DAQ board.
http://digital.ni.com/softlib.nsf/websearch/D810D65F09255FF186256F5400785B6B?opendocument&node=132070_US
When you install this driver, you will get a C function API that you can use to porgram your DAQ board in text languages. If you are programming in C, you can just call the functions (they are documented in the NI-DAQmx Base C Function Reference Help that is installed with DAQmxBase 1.4). If you are not using C, you can still use it my making calls directly into the DAQmxBase dll.
-Sal
(3,210 Views)
@salvador Santolucito wrote:
.... If you are not using C, you can still use it my making calls directly into the DAQmxBase dll.
-Sal
Could you (or anyone) give me an example of how one would do that (particularly in REALbasic)? I installed what you suggested. I presume the functional part gets installed in /System/Library/Extensions/nirlpdrvk.kext
Thanks much.
(3,197 Views)
