NI-card driver problem, Error-10401in LabView
Hi everybody!
I've a problem with the DAQmx 8.3 assistant and the native input functions.
If I want to use an analog input function to record a voltage signal, the error 10401 occurs which says the driver is not proper installed or the DAQ-card is no card from National Instruments (which it is: NI PCI 6221). The LabView Version is 7.1 and there was a previous NI card installed which I changed for a new one.
If I use the DAQ assistant (in "functions") for producing a read-in-function I can record the signal in LabView. If I try a "native" read-in-function from the function board, the previously described error occurs.
Any idea how to solve this problem?
cheers,
Ben
(3,034 Views)
hello ben,
you find a knowledgebase entry about this error here [broken link removed; article no longer available].
is the device visible and working in MAX?
regards,
robert
(3,018 Views)
