NI myDAQ and Matlab R2012b Simulink
How do I communicate NI myDAQ card with Matlab Simulink?
At the Simulink RTWin Analog Input (mask of Real-Time Windows Target analog input) have no options for Install new board like my "National Instruments myDAQ"
I'm using Matlab R2012b version.
Heliliano
Message 1 of 8
(7,421 Views)
Hello Heliliano,
According to the link below, your MatLAB version is compatible with NI myDAQ.
http://www.mathworks.com/products/daq/supported/ni-daqmx.html#myDAQ
Which version of NI DAQmx driver do you have in your computer? In order to try to fix this issue, you can try to install the last NI DAQmx version.
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
If this solution does not work, let me know.
Plínio Costa
Senior Techinical Support Engineer
National Instruments Brazil
Message 2 of 8
(7,401 Views)
Hi Plínio,
Thanks for your prompt response. Are you brazilian? Below, in portuguese, I can explain better the situation.
Eu já havia verificado o link dizendo que o MatLab R2012b é compatível com a NI myDAQ, mas mesmo assim, não encontro o modelo NI myDAQ na lista de modelos de cartões National Instruments, para configurar minha aplicação nos blocos de E/S Analógica do MatLab/Simulink.
Meu driver está atualizado com a última versão.
Se você estiver no Brasil, seria muito útil se pudermos conversar por telefone.
Muito obrigado,
Heliliano
Message 3 of 8
(7,396 Views)
Olá Heliliano,
Sim, eu estou no Brasil. Você pode ligar no nosso suporte.
(011) 3149-3149 opção 3
Cordialmente,
Plínio Costa
Message 4 of 8
(7,391 Views)
Hello.. I tried installing all the drivers starting from daqmx9.6.1 to elvis4.3 but still it doesnt show up in matlan in list of installed adaptors. And one more question, is mydaq compatible to student version matlab only??
Message 5 of 8
(6,817 Views)
Hello, i am from indonesian..
I have checked the link that says that Matlab R2012b compatible with NI myDAQ, but still does not meet NI myDAQ models in the list of National Instrument card model to configure my application in packs Analog I / O MatLab / Simulink.
can you help me.. I was working on my thesis project 😞
Message 6 of 8
(5,854 Views)
Could you find the answer if myDAQ is working in Simulink? Since I am still struggling with this.
Regards.
Message 7 of 8
(5,488 Views)
Heys, guys.
Did you refer to the link below in MathWorks Requirements and Third-Party Requirements session?
https://www.mathworks.com/hardware-support/nidaqmx.html
Ensure you have all support packages installed and you are with the right version of MatLab installed.
https://www.mathworks.com/matlabcentral/fileexchange/45086-data-acquisition-toolbox-support-package-...
Plínio Costa
Message 8 of 8
(5,482 Views)
