NI myDAQ
  I got a NI myDAQ so that I could work on my conveyor belt project at home.
In the labs at my university, the computers have some palletes that are are able to measure input output
read, write, create channel ...
  When I try to open the file on my Pc I get a question mark and few warning(search/ignore).
 Where can I find the missing palletes? During the holidays the labs have limited access and I would wish to work on it at home.
I am attaching some of the palletes that my labview cannot read. (I just copy them from the vi I did in the labs).
(3,800 Views)
Accepted by topic author A.A.A.
Have you downloaded the DAQmx driver? It looks like the only subvi's you have in that vi.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,796 Views)
In addition to DAQmx, the myDAQ needs ELVISmx. Info and downloads for both can be found at this link.
Tim W.
Applications Engineering
http://www.ni.com/support
(3,789 Views)
After I saw the hyper link I saw that it does not support LabVIEW 2011.
I tried it on LabVIEW 2010 and I found the sub vis 🙂
Thank you.
P.S.  I ran the CD that came with the myDAQ and it solved my problem 🙂
(3,780 Views)
Is there a downloadable ISO image for the myDAQ disc? I bought a used myDAQ kit and the box was missing any discs. I'm trying to do a hobbyist rig with DIO for my Christmas light display, so low budget. Thx.
(1,093 Views)
NI myDAQ Driver and Software Requirements
myDAQ Software Suite Download
https://tmesystems.net/
(1,085 Views)
