NI6224 Analog In Driver
I coded an RTX driver following the flow in example aiex1.cpp.
What changes are needed to setup for single ended common ground, instead of differential?  Is it necessary to have a voltage present on the 6224 during integration testing?
After initialization the JOINT_STATUS_2 returns 0x90 indicating that AI_Scan_In_Progress_St, and AI_EOC_St.
Since NI doesn't provide a manual I have no idea what this means, except that these flags never clear.  Can't read from the FIFO unless the AI_Scan_In_Progress_St clears.  So where is the FIFO data?
(3,379 Views)
Hey lorenze,
Thanks for contacting National Instruments support. This is actually a DDK question and there is a special forum for those questions that are answered by R&D, please post this question there.
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(3,363 Views)
