NI9201 and NI9263
I actually try to acquire data with the NI 9205 and I want to generate square signal with the NI9263 in the same VI but it doesn't work. The 2 board are on a cDAQ 9174.
I really need help. Where can I found example about how I can use this two parts together.
Renaud
(3,902 Views)
Hi Renaud,
open the NI Example Finder (Help --> Find Examples) and limit examples to hardware. (see attached screenshots)
You can use
- "Voltage - Continuous Input.vi" for example with 9205 or 9201.
and
- "Voltage - Continuois Output.vi" for example with 9263. In this example you can choose a square wave signal with special frequency and amplitude to be generated.
Hope this helps.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(3,784 Views)
