06-05-2012 10:12 AM
I'm trying to take samples every 0.1 seconds from an NI9219.
I set up then converted a DAQ Assistant to code, because I had to change the AI.ADCTimingMode to High Speed. Sample rate is set to 10 Hz, and the samples to read are set to 1. This is all in a while loop. However, each iteration through the loop is returning 10 samples every one second, not 1 sample every 0.1 second.
The VIs are attached if it will help, LV2011 format.
Thanks in advance to any who take a stab at enlightening me as to why this is!
Solved! Go to Solution.
06-05-2012 11:41 AM
Ack, had the "number of sample" input of the DAQmx Read VI wired up inadvertantly. Disregard! ![]()
