NIDAQ
I'm trying to install the NI DAQmx, and compile .h and .lib files. The problem is that the 64 bit folders with this specific files aren't available there. When I try to run the mex compile this shows errors related to the architeture of the PC. I have a 64 bits pc, but when installing the NI drivers only the x86bits shows up.
(647 Views)
I am not sure what you are trying to do with mex compile.
If you are using MATLAB, use Data Acquisition Toolbox
If you are using C programming, the 64-bit library is available at C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64
https://tmesystems.net/
(619 Views)
