NIDAQMXBASE.DLL
I have a usb6008 card. I installed nidaqmx 7.5 and labview 7.1.
Now, i want to use Delpih to buid an application with this NI hardware.
I need nidaqmxbase.dll to work with delphi. My nidaqmx7.5 cd doesn´t install this dll file. Where cani get it?
(4,527 Views)
That DLL is installed to the Windows\System32 directory when NI-DAQmx Base is installed. Since the USB-9008 is supported in NI-DAQmx. I would recommend to  use the DAQmx API to program your device.
Check the following link to know how you can call the DAQmx API from Delphi :
Regards.
Omar S. NI
(4,511 Views)
I want to access my USB from Java, for that I must have .dll instead of .lib libraries, it is enough to import functions from nidaqmxbase.dll or I need to import functions from other of the .dll listed in Windows\Sysem32??
best regards
Gerardo
(3,311 Views)
