NIDAQmx 64 bit library for AnsiC not found
Hi everyone,
I use a niDAQmx solution in a custom MSVC application. Everything is fine in case of
a win32 build. However, in the x64 build, I can not find the import library.
I found a discussion with a solution for this problem with version 9.8 of the niDAQmx
installation software here:
http://digital.ni.com/public.nsf/allkb/0A58C96A9ECF3E27862577420050B500
Unfortunately, I do not have the folder
<Program Files>\NationalInstruments\Shared\ExternalCompilerSupport
on my system. The other post says that I need to activate "install ANSI C support" in the custom installation.
Well, I checked it multiple times, this option is active. As it seems, that is the default install option.
Nevertheless, no 64 bit library is present on my system.
Can anyone please help here?
Thank you and best regards
Hauke
(4,181 Views)
Ah, found it right after sending the message, it is under C:\Program Files (x86) and not C:\Program Files\. There are "Shared" subfolders at both locations...
(4,180 Views)
