NIDAQmx Base: runtime error, can't find LabView!?
G'day,
I'm writing an applciation that will interface with NI USB-60xx hardware via the NIDAQmx Base API.  I've got the latest version 3.5 and I can run the precompiled exampleswithout any issues.  However, if I compile and run the example source code I get a heap of runtime warnings (see attachement) about missing objects for .cpp files.  Some of these objects are expected to be in Labview folders.
Why have I got errors for C++ files when I compiling C?  Why are these errors looking in the home directlroy for a user called /lvbuild (I have no such user)?  Why should I require objects not provided in the NIDAQmx Base package to use it?
The attatchment is the list of runtime warnings after compiling the 'contAcquireNChan.c' example source file.
I am compilling with the frameworks nidaqmxbase, nidaqmxbaselv.
I am compiling under OSX 10.7.
Thanks for any help,
Lee.
(3,753 Views)
Hello Tangle,
Thanks for letting us know about this.  I just tried again and lucky for me, I can't reproduce the behavior that you are seeing.  Here is what I did to try to reproduce the problem.
1. Reimage to a clean 10.7 system with Xcode installed.
2. Install NI-DAQmx Base 3.5 on the system. (reboot)
3. Navigate to "/Applications/National Instruments/NI-DAQmx Base/examles/ai" via the terminal
4. Type "make" and watch the examples build.
5. run "./contAcquireNChan" to run the example.
I received the usual samples from this example.  I have a few questions for you to understand this better.
1. Is your kernel in 32-bit or 64-bit mode? (I've tested it on both in the past...just want to make sure)
2. Are you able to reproduce this issue with the process I listed above?
3. If not, what are you doing to reproduce the problem?
Steven T.
(3,739 Views)
Steve,
Thank you for you reply.
I can't get back to a clean 10.7 install without loosing two days.  However, I have followed your process starting at step 2.
When I make the files at the terminal (as you describe) I do not get the same runtime warnings.
I am using xCode to develop my application.  I did trace these runtime warnings to adding the nidaqmxbase and nidaqmxbaselv frameworks to my xCode project.  Even if I remove all my NIDAQmx Base function calls, just having those frameworks in the project (and linking to them) results in these warnings.  If I remove the frameworks, the warnings disappear.  However, I then tried to reproduce the warnings in a fresh xcode project, and could not.  I went through and made sure that the compilers, compiler flags, etc all matched, but adding the frameworks did not cause runtime warnings in a fresh xcode project.
It must be some specific quirk in my application's project setup that for some reason is interacting with these frameworks in a strange way.  When I have time to do so I will bring my source code across to a fresh project to see if I can identify what is triggering the warnings.
Thank you for your time.  If you have any ideas, please let me know.
Lee.
P.S.  I find it ammusing that you forum's spell checker does not know the words LabView or NIDAQ
(3,726 Views)
Hello Tangle,
The idea that my colleague had is that xCode could be enabling some type of debug build of your project.  I haven't used xCode, so I can't tell you exactly which setting it could be.
Funny, somehow NIDAQmx gets corrected to Indiana in the spell check!
Thanks for the details!
Steven T.
(3,723 Views)
Steve,
I was using a debug build, but now have switched it off.  It did not changed anything.
I I have since tried moving my source code into a new project and that removed the runtime warnings for the examples source code, most of the time.  Now sometimes, maybe 1 in 5 times that I run, I get the same runtime warnings at the end of the task (previously they occured when the sampling task started).
Lee.
(3,704 Views)
