NIDAQmx base and and app delegates on the Mac
I ran into problem with app on mac and nidaqmx base drivers. It is related to forum reports and NI CAR# 611729 I think.
This problem seems to be reported by many users since more than 2 years with a different CAR # (#528664)
https://forums.ni.com/t5/Multifunction-DAQ/NIDAQmxBase-calls-on-MAC-OSX-crashes-UI-application/td-p/...
https://forums.ni.com/t5/Multifunction-DAQ/NIDAQmx-15-0-and-and-app-delegates-on-the-Mac/td-p/327730...
Is this been resolved in 17.x of the nidaqmx base drivers? No mention in the readme files. Please fix the problem!!
(3,081 Views)
This issue is currently being investigated by the support/R&D teams. It is something that our engineers are aware of, although it has not yet been fixed.
Anthony M.
Applications Engineering
(3,007 Views)
I am also running into problems running my NI-cards on the Mac (NIDAQmx Base 15). The code is written in C and compiled with XCode (7.3) under ElCapitan (10.11). The compilation is executed without errors and I can execute the created 'mex'-file properly until the first reference to the NI-code.
The code runs perfect under MountainLion (10.8) called from a 32-bit application. As you can tell by the versions of OSX used, I have been postponing the transition to 64-bit for several years. I cannot, however, wait any further, because I need some critical other functionality that is tied to 64-bit applications.
Do you have any idea about when one can expect a solution?
MacPsi
(2,830 Views)
The problem reported in CAR #528664 was marked as fixed and tested with OSX 10.11.4, Xcode Version 6.1.1 using LabVIEW 2016. Have you had the chance to test it in LabVIEW 2016 / DAQmx 16.X version?
As for the newer CAR #611729, I unfortunately cannot speak to a specific timeline for a fix, as this is still under review with R&D.
Paige C.
(2,820 Views)
