NIDAQmx wrapper problems
I am currently trying to drive a NI USB-6009 device via Java but when I run my program nothing happens so I wonder if someone here could help me. Everything in my code is based on the examples given by NI.
The java side of my program:
public
class UpdateVoltage{
   private native void UpdateVoltage();
   static {
      System.load("C:/Documents and Settings/AntoineG/My Documents/Java/Projects/DataAcquisition/src/libTest2.dll");
   public static void main(String[] args) {
      new UpdateVoltage();
The C-code side of my program (which generates libTest2.dll)
* ANSI C Example program:
* WriteDigChan.c
* Example Category:
* DO
* Description:
* This example demonstrates how to write values to a digital
* output channel.
* Instructions for Running:
* 1. Select the digital lines on the DAQ device to be written.
* 2. Select a value to write.
* Note: The array is sized for 8 lines, if using a different
* amount of lines, change the number of elements in the
* array to equal the number of lines chosen.
* Steps:
* 1. Create a task.
* 2. Create a Digital Output channel. Use one channel for all
* lines.
* 3. Call the Start function to start the task.
* 4. Write the digital Boolean array data. This write function
* writes a single sample of digital data on demand, so no
* timeout is necessary.
* 5. Call the Clear Task function to clear the Task.
* 6. Display an error if any.
* I/O Connections Overview:
* Make sure your signal output terminals match the Lines I/O
* Control. In this case wire the item to receive the signal to the
* first eight digital lines on your DAQ Device.
/* National Instruments / Data Acquisition */
/* Copyright (c) National Instruments 2003. All Rights Reserved. */
/* Title: NIDAQmx.h */
/* Purpose: Include file for NI-DAQmx library support. */
#include
<stdio.h>
/* DO NOT EDIT THIS FILE - it is machine generated */
#include
"jni.h"
#include
"NIDAQmx.h"
#pragma
comment(lib,"NIDAQmx.lib")
/* Header for class EnvoiDigSignal */
#ifndef
_Included_EnvoiDigSignal
#define
#ifdef
__cplusplus
extern
"C" {
#endif
* Class: EnvoiDigSignal
* Method: EnvoiDigSignal
* Signature: (Ljava/lang/String;[I)V
JNIEXPORT
void JNICALL Java_EnvoiDigSignal_EnvoiDigSignal(JNIEnv *, jobject);
#ifdef
__cplusplus
#endif
#endif
JNIEXPORT
void JNICALL Java_EnvoiDigSignal_EnvoiDigSignal(JNIEnv *env, jobject obj)
   int32 error=0;
   TaskHandle taskHandle=0;
   float64 data[1] = {1.0};
   char errBuff[2048]={'\0'};
   // DAQmx Configure Code
   DAQmxCreateTask(
"",&taskHandle);
   DAQmxCreateAOVoltageChan(taskHandle,
"Dev1/ao0","",-10.0,10.0,DAQmx_Val_Volts,"");
   // DAQmx Start Code
   DAQmxStartTask(taskHandle);
      // DAQmx Write Code
      DAQmxWriteAnalogF64(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL);
I've checked, my device name is Dev1 and I am looking at a voltage from the AO0.
(3,309 Views)
I pasted the wrong version of my C code and I can't edit, so in the actual version UpdateVoltage have replaced EnvoiDigSignal.
(3,305 Views)
Ok I found the problem, at least I think so. I think it was a problem with DAQmxCreateAOVoltageChan function and more pricely the voltage range of -10,10 I was entering. I think that was a too big range for my NIDAQ card, now I have put it down to 0,5 it is working fine.
(3,299 Views)
