NIDaq.pas file
I have to use a DAQCard 6533 in a Delphi 7 environment.
I also have to use the Traditional NI-DAQ driver ver 7.4.4.  Unfortunately Delphi is not longer supported in this version.
So before using the card, i have to re-write the interface file with the NIDAQ.dll file if it not exists.
Anybody know if a such file exists ? And where can i find it ?
Thanks for your help.
Pierre_Net
(4,171 Views)
Hi Pierre,
I found this link where they say that no such file exists.
But there is some more information that may be usefull for you.
http://digital.ni.com/public.nsf/allkb/6DA2B77222315EE08525644B0077C1CA?OpenDocument
I hope this helps you. Good Luck!
Kind Regards,
Joris Donders
EMEIA GTM Lead for Semiconductor
www.ni.com/semiconductor
(4,133 Views)
Hello!
Could yo help me...
 I can't download nidaq.pas file from this page
http://digital.ni.com/public.nsf/websearch/6DA2B77222315EE08525644B0077C1CA?opendocument&Submitted&&node=133020_US
link "nidaq.pas" is not active... How can I download this file?
Thank you !
(3,866 Views)
hello
Attached the modified pas file.
Works with delphi 7 (and 😎
Ulrich
(3,853 Views)
Thank's! That's what I need !! 🙂
(3,839 Views)
