NIDaqmx on windows XP
Hi. I was using LV2014 until last year and now I upgraded to LV2017. One LabView program that I am using is installed on Windows XP, Win7 and Win10. I made a important change on this program and all was ok on win7 and win10, but LV2017 is not running on WinXP. I made a copy and saved all my project for a previous version (2014). However my program use NIDaqmx and when I try to run the new execute on XP the next message appears:
"LabVIEW: Resource not found
An error occurred loading VI 'DAQmx Create Channel (AI-Voltage-Basic).vi'.
LabVIEW load error code 3: Could not load front panel."
Who knows how to solve this issue?
Thanks in advance
(4,201 Views)
Which DAQmx driver did you install?
NI-DAQmx and Microsoft Windows Compatibility
DAQmx provides XP support up to 15.5.1.
Certified LabVIEW Developer
GCentral
(4,169 Views)
Hi joengomez:
     Unfortunately, LabVIEW 2017 is not compatible with Windows XP, so this might be the cause of the issue.
(4,159 Views)
