NIdaqmx (BASE) confusion
Ok, I'm really confused now.
I understand NIdaqmx and NIdaqmx Base have not much to do with each other exept for the looks of the subVIs.
I have programmed a linux-box with a 6034E using NIdaqmx Base without problems. I was completely happy because NI seems to be closing the gap between WIN and Linux.
Now I took the same card (6034E) in a Windows-box and tried to run that VI but I get an error -200220 (device identifier is invalid).
I tracked that down to the following problem:
The Windows-Box has both NIDaqmx and NIdaqmx Base. Using MAX, the 6034E is found inthe traditional DAQ and DAQmx (Dev1).
When I start the NIdaqmxBase Task Config Utility, the board is not found.
Now I get the feeling DAQmxBase supports more devices under Linux than under Windows. Is that right? In that case you really got me confused. My goal has always been to be platform-independent. That's one reason for using LV in the fist place. If that is the case, why use the name DAQmxBase? For my ears that sounds like the base=low level DAQ (that all OSes are using) and DAQmx is one level above that. But that's not the case. It takes about one day reading the forums to find out, that DAQmxBase and DAQmx are as different as cats and dogs.
And then, DAQmxBase and DAQmx are huge and slow-loading (a simple single point aquisition vi loads about 900 subVIs. Polimorphism is ok, but here it looks like I am loading the support for every NI-board ever sold. That gives me the feeling of swimming in a lake wearing workman's boots).
Besides all criticism, thanks for "going linux" with DAQmxBase.
-DB
(3,039 Views)
on windows systems the NI-DAQmxbase supports the "low cost" usb devices (now ni-daq 7.5 supports them too).
for an overview i will refer you to the following page: http://www.ni.com/support/daq/versions_pci_pxi.htm
(3,028 Views)
I think "Base" means "basic functionality" not "the base supporting everything on top of it".
In fact, there's *lots* of functionality missing from NI-DAQmx Base.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(2,992 Views)
