NO DAQmx device and how can i use DAQmx as virtual
Hi everybody.
need help. actually i am working on DAQmx for current. i want to know how can i use DAQmx if i am at home. i cannot have device all time with me. tell me about virtual DAQmx by making setting on my DAQ program that its virtually attached. i want to see my output without hardware
Regrads
Qasim
(4,204 Views)
HI,
one of my friend help me regarding DAQ about virtual..i have design DAQ virtual using NI max software but now this error occured
i have done that ad still getting 2 errors.  i have attached files. i m using virtual DAQ
(4,182 Views)
According to the error, you are trying to set the minimum value to something outside of a desired range of +-40mV.  What device are you using?  Can you share some of your code?
(4,179 Views)
Hi
i have attached a doc. actually i want to run 2 DAQ devices together. as virtual DAQ i cannot fix on current. with voltage it run with one DAQ and i get simulated signal on DAQ 1 only other donot give any simulated signal. kindly help me. i have make DAQ using Ni max and run in this program in block of physical channel.
i try to send u my file .vi but it cannot be attachedso i m sending u pic of my work
(4,156 Views)
