08-23-2007 05:10 AM
08-24-2007 05:30 AM
08-24-2007 06:23 AM
Hi Abhinav
Thanks for reply. I have further query to ask given hereunder.
1. For NRSE mode , it is clear that -ve of measured point has to go to AI Sense , what I would like
to know where do I connect the AI GND of DAQ , can this be left open or else connected to AC
earth. If I am just measuring o/p voltage of a power supply ( Grounded source ) , there are 2
measument points +ve which goes to channel i/p ( AI i/p) , -ve to AI sense , where to connect
the AI Ground of DAQ.
2. For a grounded type source , if I use RSE scheme then is there any need for connecting
AI sense to AI GND ?. I have gone through the ni application note on field wiring & ground scheme,
it says if yr measument voltages are above 1 V , then RSE type scheme can be used for
grounded system.
Thanks Vinod
08-24-2007 06:36 AM - edited 08-24-2007 06:36 AM
Message Edited by Abhinav T on 08-24-2007 06:37 AM
09-01-2007 05:08 PM
Hello Abhinav
Thanks for yr reply.
I have few queries on differential mode measurement & use of scaling resistors.
1. What is the allowed o/p source impedance of UUT that would not affect the measurement in differential mode , I am going to use NI USB M6229 DAQ.Ideally source impedance of measured point ( e.g power supply o/p) should be zero .
Say I have to measure 24 V in a grounded source & I want to use differential mode. I would require scaler to
lower the voltage . If I use a scaler combination 100K / 33K ( 1/4 scaling ) to lower the voltage to 6v , now I
am measuring voltage across 33K , one end to ai + , & other end of 33K ( which is also PSU -ve) to ai- ,
Whether this can be measured correctly by DAQ.
but for other ai- it is none as connected straight to -ve of PSU ; Can this create any problem in measurement
imbalance from point of view of differential measurement.
3. In the above case do I need to connect any series resistor between one measurement point ( 33K one end)
and ai+ point for protection. Similarly other end of 33K ( which is -ve of power supply ) to ai - can be connected
straight away or series resistor is required.
( I am attaching the schematic)
Thanks Vinod
09-05-2007 05:07 AM
09-12-2007 03:24 AM
Hello Abhinav
I have a query regarding value of resistors to be chosen for differential measurement involving a floating source , between AI ( analog input channel) and AIGND at DAQ
. Application note recommends value between 10K to 100K , some members in forum have said
that upto 1M can be used. At some place in an NI article it says 100 times the source impedance.
Can you please clarify whether I can use a value above 100K. I have now selected 33K || 10 K scaler ,
I have tried using 100K between AI to AIGND but it slightly changes the actual voltage about 5% to 8%.
Thanks Vinod
09-25-2007 12:37 PM
Hi vki
Something that might be changing the voltage slightly is the precision of the resistors. But I will like to ask you are you still doing the “voltage divider” that you have attached. The voltage that you are going to be measuring is the drop across the 33K resistor so this resistor, I would recommend to select a 1% precision resistor. But as far as the connection it seems that you have everything connected correctly.
09-27-2007 01:23 PM
Hello Jaime
I would like to state
1. Error in voltage is not linked to precision of resistors , when I remove the connections from DAQ
inputs & measure with multimeter it gives me correct voltage measurement , however when I
connect these to DAQ inputs in a differential config. ( 100 K resistors connected from AI to AIGND ) voltage changes giving roughly 4-5 % error.
2. NI application note recommends that resistor between differential input to AIGND should be
10K to 100K or else 100 times the input impedance. For this measurement I changed the
resistor scaler from 100K || 33K to 10K || 3K which gave me better results & error reduced.
3. Other then above , I have a requirement to generate a sine wave to feed a RC network & measure
voltage ; I am currently using Labview 7.1 , can you recommend a vi or some application note
which can help me in this.
Vinod
09-30-2007 03:41 PM
