National Instruments NIDAQmx software not listed in Add/Remove Programs
I need to uninstall DAQmx 8.3 from my system. If i go to Add/Remove Programs it does not display this software.
1. How can i uninstall?
2. I checked in few posts which suggest to use msiBlast.exe? Is is advisable to use this utility to uninstall
3. Is there any other option to make the software list the Add/Remove Programs?
Thanks a lot,
Asha
(3,823 Views)
In Add/Remove Programs, select National Instrument Software.
(3,819 Views)
I cannot see the "National Instrument Software" in Add/Remove Program
Hence i wanted to know whether it is advisable to use msiBlast.exe to unstall?
or
Is there any other way we can make the software list in the Add/Remove Programs?
(3,815 Views)
I see in one of your other posts, you had done an upgrade and had problems. With the installation of different versions, it's possible that the windows registry got all messed up. I've used msiblast in the past with good results. I would recomend that you remove the hardware, reboot, run msiblast, reboot again, and then try re-installing the software.
(3,808 Views)
Thanks a lot!
It worked.  As per your recommendation i used msiblast to unstall all the National Instruments
(3,775 Views)
