National Instruments mDNS Responder Service
I suffered the same problem, MAX discontinued to recognize my PXI cards, after upgrading java to 1.6.0_32, as requested by our local IT.
As a consequence, NI-mDNS Responder did not start automatically or stopped. And in turn nidevldu was not started.
Setting properties of Service->Recovery to "Restart the service" for 1st, 2nd and subsequent failures did not help either.
All investigations to trace down the problem cost me nearly a working day, until I discovered this discussion thread.
The offered zip Package with NI mDNS Responder 2.1.0 did it !
Now NI services start automatically upon boot as  expected (although properties are reset to "Take no Action" on failures)
Could NI give us some more detail, on what went wrong and what is fixed now please ?
Message 51 of 67
(2,915 Views)
just to clarify:
filename of zip file offered inthis thread for download by Justin E. indicated version 2.1.4,
however installer confirmed „NI mDNS Responder 2.1.0 has been successfully installed“
Guess, that the not yet released version 2.1.4 of mDNS Responder was packed, using the previous installer.
Message 52 of 67
(2,912 Views)
I'm having the same problems as everyone else.  I can't even get mDNS responder to start manually.  Currently uninstalling everything and going to give it another go.
Justin, could I get that file for NI mDNS Responder 2.1.0?  Thanks
Message 53 of 67
(2,845 Views)
Hi CHersh,
This is Marcus from Application Engineering.  What errors are you seeing?
Marcus
Marcus M.
PXI Product Support Engineer
Message 54 of 67
(2,815 Views)
Hi Marcus,
The reinstall took care of the problem, so I had the oppertunity to mess around with signalexpress today.  Maybe you can help me with a differnt problem I'm having (email is cjh5293@psu.edu if you don't want to go OT).  I want to take a voltage data point every 10 minutes or so for a few days.  I think I got it to work (had to change timeout to -1), but now when I stop the log it hangs in 'stopping' mode.  I found this article that I hoped would fix it, but it turns out that I already had that option set to 'no' (and I already was using the save to ASCII step) .  So now I'm stuck again.
Chris
Message 55 of 67
(2,813 Views)
Hi Chris,
Please start a new thread for this topic, this way the appropriate engineers and community will be able help you resolve your issue.  By keeping the threads separate R&D is able to actively track popular topics to help improve our future products.
Marcus
Marcus M.
Message 56 of 67
(2,799 Views)
I also post this here to prevent people from having to search all over the Forum for this file due to cleaned up and therefore invalid FTP Links.
rename C:\Program Files\National Instruments\Shared\mDNS Responder\nimdnsResponder.exe to nimdnsResponder.bak, and place this new executable there. Restart the system and see if the service starts up or if they continue to get errors.
This is a File we do not take Responisibility for since it is not officially distributed. Please see it as a help-your-self workaround until the final fixed Version is beeing released.
Message 57 of 67
(2,775 Views)
The zip has been removed from the above post. If you need this patch, feel free to post to request it and we can send a copy. However, since the software hasn't been released yet, it will only be sent out by request rather then available for public download. This process will allow for a better depiction of how often the patch is required.
Kind Regards,
Luke West | Product Support Engineer | National Instruments
Message 58 of 67
(2,755 Views)
I am getting the mDNS responder not starting with an error of -1. I was told by the App eng I was working with to post here to get the later version to see if it will help.
THANKS
Jeff D.
Certified Architect LabVIEW Champion DQMH Framework
Message 59 of 67
(2,701 Views)
