Need S Parameter Model
Hi Team,
We are going to use PCIe-6537B board to support our main board.
PCIe Board Description: NI PCIe-6537B Digital I/O (50 MHz, 2.5/3.3/5 V, PCI Express)
Below are the cables which will support to connect both the boards. we want to see insertion loss, return loss and reflection. So that we need S parameter model for the below cable part to do simulation. Kindly provide the models.
P/N 192061-0R5 (0.5 m).
P/N 192061-01 (1 m)
P/N 192061-02 (2 m)
P/N 191945-01 (1 m).
(2,121 Views)
I want S parameter model for 785633-01 this connector part as well.
(2,103 Views)
Kindly provide the solution as soon as possible.
(2,090 Views)
Hi Team,
Kindly provide the models for below cables.
P/N 192061-01 (1 m)
P/N 192061-02 (2 m)
And also I want S parameter model for 785633-01, this connector part as well.
(2,092 Views)
Duplicated with Need S parameter model setup
(1,993 Views)
This is not official communication medium with NI, this is a public forum where fellow users help each other. We can help search and find only publicly available information. Based on my past experience and public information, S-Parameter data is not provided for mixed signal cable assemblies.
Santhosh
Soliton Technologies
(1,987 Views)
Please stop creating further duplicate posts, posting the same question 100 times will not help get answer, there are only a set of regular users helping the newcomer and they look everywhere.
https://forums.ni.com/t5/Digital-I-O/Need-S-parameter-model-setup/td-p/4411642
Santhosh
(1,983 Views)
