Need help with USB 6009.
I have a 6009 that is giving me problems. The light flashed green on a PC with no NI software installed. Everything appeared to work with DAQmx base 15.0 installed. I updated the FW using the executable in Program Files x86, and it stopped working.
After that will not light up with DAQ mx base 15.0,  2022 Q3 and 2022 Q4. It populates a unknown device or USB Flash loader in Device manager. Manually changing the driver will get it recognized and open NI MAX, but all tests come back with error codes. Nothing seems to be able to talk to it.
The only success I have had is by taking it back to a different computer with DAQ MXBase 3.0 installed. The computer recognizes the DAQ, and NI datalogger gives a graph of tiny voltages when I hit the "play" button. As soon as it goes to the other PCs, it will blink twice and then all tests fail with "Status Code: -88705
The specified device is not present or is not active in the system. The device may not be installed on this system, may have been unplugged, or may not be installed correctly."
I take it back to the base 3.0 for  FWupdate.exe to get it going again.
All computers are Windows 10 OS.
What do I have to do to the 6009 so I can eventually use it in LabView Community Edition? (newest NI-DAQmx versions).  Services are not the issue, they are running fine on all the computers with the newest versions.
(1,143 Views)
Try Using a USB-6008 / 6009 / 6501 in MAX, and Switching Firmware Between NI-DAQmx and NI-DAQmx Base and switch the hardware to DAQmx
https://tmesystems.net/
(1,131 Views)
