Network Device Recognized, Hower Cannot Add Device: Error -201251
Hello NI Community,
I have an NI cDAQ-9185 running on NI MAX 17.1.1.  I am connected to my laptop with an ethernet cable.  My computer recognizes the device, but the device cannot be added.  I get Add Device -201251 error.
I have uninstalled and reinstalled NI MAX.  The cDAQ was working just last week with this version of MAX.  LabVIEW 2016 is also installed on the laptop.
I have been searching the forums for a solution and have not been able to find one. Any recommendations would be much appreciated. See attached photos of errors.
Josh
(2,798 Views)
Josh,
This error is usually seen when there is a firewall active that is blocking communication. The article below addresses this issue and should give you some next steps in troubleshooting your device.
Error -201251 When I Try to Add a Device in NI MAX
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RmdSAE&l=en-US
(2,767 Views)
