[New Be] ANalyse Signal with USB-6009
I already told you the name of the driver. You also got it with the device. If you have a compatible programming language installed, examples will also be installed.
Message 11 of 15
(2,109 Views)
Well I have the driver install but didn't check yet on Visual Studio.
Message 12 of 15
(2,107 Views)
Don't forget that LabVIEW for students is free.
Message 13 of 15
(2,104 Views)
I didn't know but still I do not how to use it while I know about VS, but thank for the information.
Message 14 of 15
(2,099 Views)
hello everyone,
I am trying to read an analogue signal with a USB 6009 with Measure Studio. I didn't find tutorial which explain methode and function on measure studio to do it
What I want to do it just read one analogue input  and mesure the time between two signal peak. The thing is I found thing but either for temperatur or all signal without function to measure time.
i want to know the local maximum and the time between two maximum. I will use local maximum to calculate roort mean square and the time to find the mean time between to local maximal.
If followed this one : https://ww2.distek.com/blog/daqmx-measurement-studio/ but I didn't get what I wanted.
If someone knows how to do it it will be really help full.
Message 15 of 15
(2,057 Views)
