Ni USB 8451 Cannot work
Hi All,
My Ni USB 8451 cannot work suddently, checked in PC device manager, it was change to "NI USB-8451 firmware loader ", when it is normally, the device name is "Ni USB-8451"
(2,423 Views)
How about on another computer? - would help to identify if the instrument was bricked somehow or just your computer was messed up.
Try resetting NI MAX too,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
Santhosh
Soliton Technologies
(2,385 Views)
Had tried with different PC,and tried different Ni USB 8451 with same PC, confirmed only this unit failed in this.
(2,382 Views)
Had reset the NI MAX, but it didn't solve the issue, I guess the firmware was lost.
(2,375 Views)
Best to reach out to NI Support https://www.ni.com/my-support/s/service-requests
It may be possible, you could recover it or worst case, you need to buy a new one.
Santhosh
(2,372 Views)
Hi, I have the same problem. have you solved it?thanks.
(1,986 Views)
I replaced the it by NEW Ni USB 8451.
(1,979 Views)
