No soft panel for pxie 5105
I have a PXIe 5105 on a RT platform. In MAX the card is seen and the self test works along with the ability to reset the device. However, if I open the test panel an error message comes up saying that NI does not detect any digitizers in the system. I am working form a Windows 8 machine to connect to the remote RT PXI platform.
avantibob
(3,245 Views)
Hi avantibob,
Are you trying to access a SCOPE Soft Front Panel or are you trying to access a Test Panel in MAX?
Josh B
(3,231 Views)
Josh,
Thanks for your post I got the answer from Jacob about the test panel and also why my vi is freezing. I read the getting started to fast and did not see that NI-SCOPE Soft Front Panel is not supported in LabVIEW Real-Time Module. As for the freezing I do not have enough memory on the module to be compatible.
Bob
avantibob
(3,228 Views)
