Noise between DAC and counter 0 on DAQ USB 6215
Hello
We are reading a signal from a quadratic encoder on a DC motor with a frequency at 33 kHz. We are reading the signal on counter 0 and we don't have any problem reading the signal. Also we use the DAQ to make an AO voltage through a servo amplifier to a DC motor. The problem is the we can't count proberly when we use 1 DAQ. If we use 2 DAQs we dont have any problem.
How can the DAC disturb the counter?
Thanks in advance
- Henrik
Message 1 of 1
(3,180 Views)
