Normalization of two different signal
Hi
I have two different signal that is Ch1 and Ch2
Then I used Normalize Waveform vi to tranform the waveform data so that its maximun is 1 and its minimum is -1 just like the signals below.
Supposely when I divide this two signal, I should have an output like signal below
but what I get is like this signal below
Why is this happen? I attached the VI here
(3,558 Views)
Hey yusof,
You are dividing by zero at the points where it diverges. Otherwise, it just fluctuates between 1 and 1 which is likely just due to quantization. Hope that helps!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(3,544 Views)
it helped a lot sir, thanks
(3,383 Views)
No problem.
John B.
(3,367 Views)
