OPCServer Nidaqopc cannot start ! Error is: 0x80010105 Help me!!!
I own a Lab-pc+ board and I cannot start the OPC server.
Installation of NIDAQ 6.92 and the hardware installation of the motherboard were succesfull.
In Server Explorer for Daqopc, on first attempt to connect to server, it gives an 0x80010105 error!A currently have installed DCOM version 1.3.I would appreciate some help on this, thank you.
(3,481 Views)
The first thing I would suggest to do is to install the newest version of NI-DAQ that supports your hardware which would be NI-DAQ 6.9.3. I would suggest to uninstall NI-DAQ 6.9.2 and install NI-DAQ 6.9.3 from the link below. This will assure that we are not dealing with anything that has been fixed in the newest driver version. I have also included links to troubleshooting tools on our website. The first link goes into verifying the installation of the OPC Server by using a Microsoft utility, "Dependency Walker 2.0", that allows you to select a "*.EXE" and view all of the DLL's (typically dozens!) that the program is linked to. You could use this utility to verify a good install of the server. I hope this helps.
NI-DAQ OPC Server Troubleshooting Wizard (V
erifying Installation)
http://www.ni.com/support/labview/dsc/daq_tr8.htm
NI-DAQ OPC Server Troubleshooting Wizard (known issues)
http://www.ni.com/support/labview/dsc/daq_tr9.htm
Using the Server Explorer to Troubleshoot DAQ-OPC Server Communication
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/f4346c03b087f01986256b9900730c01?OpenDocument
Todd D.
(3,481 Views)
