OS driver for 6071E on NI-DAQMX v8.7.1?
In our latest shipments we have received the new version NIDAQ-MX v8.7.1. But the card, which is a 6071E, does not seem to be supported by this sw. On earlier versions like 8.6 the driver was installed automatically, but not in the new one. When trying to install a driver manually the card does not show in the list.
Message 1 of 9
(4,016 Views)
Message 2 of 9
(4,012 Views)
Accepted by topic author Atele
The latest version is actually 8.9 and in the readme, the 6071E is listed. Try installing this.
Message 3 of 9
(4,007 Views)
Thanks for your quick responses. I'll report when the testing of 8.9 is completed.
Message 4 of 9
(4,001 Views)
Thanks again. Version 8.9 solved my problem 🙂
Message Edited by Atele on 03-27-2009 08:40 AM
Message 5 of 9
(3,980 Views)
Could you please do a favor? Please mark Dennis post as solution to your problem and not your post. Hope you understand.
Mathan
Message 6 of 9
(3,962 Views)
Sorry about that. I understand. But how do I change the tag? I can't find where to remove / add the solution label.. Anyone?
Atle
(Novice)
Message 7 of 9
(3,947 Views)
In your post which you marked as solution, just click on the Options menu located at the top right corner of that post and select "Unmark" . Then click on the options menu at the top right corner of Dennis' post and select "Mark as solution".
Mathan
Message 8 of 9
(3,943 Views)
Actually I tried that one without succeeding. I seemed to be logged in to the NI site, but not this forum / board. BUT when I noticed that I managed to log in here also. Thanks for all your help.
Message 9 of 9
(3,936 Views)
