OSError when using nidaqmx-python
I want to use nidaqmx-python to read data from NI cDAQ-9184.
The example code can't be executed correctly,and python produces: OSError: [WinError 193] %1 is not a valid Win32 application.
I use Anaconda 3, and create a virtual environment, which Python (64 bits) version is 3.6.9. I install nidaqmx which version is 0.5.7.
I use Windows 10 (64 bits), install labview 2015 (32 bits) and NI MAX.
After some unsuccessful attempts, I find I can executed the example code correctly in Python (32 bits), Python3 (32 bits) is my python in my operating system. But I want to use Python (64 bits) in the future.
(I am sorry for my poor English expression.)
(3,571 Views)
Accepted by topic author WuTUT
Hi WuTuT,
From your description I assume the bit version of python should match that of labview, which means you should have 64-bit labview installed before you can use nidaqmx package in 64-bit python.
It's only my assumption, correct me if i'm wrong
Regards
(3,515 Views)
After install labview 2018 (64 bit) and NI DAQ 18.0, I can run the code in Python 3 (64 bits) correctly. So I think you are right.
Thank you for your help !
Regards.
(3,502 Views)
