Obtain two seperate channels from multi channel input to the read.vi
Hi
When multiple channels are read by the daqmx read.vi it gives a 1D array containing samples of the multiple inputs. How do you seperate this 1D array to two or more independent arrays.I have included my solution but am not sure whether it is correct.
(The first vi is in this)
Mal
(2,774 Views)
I checked out your solution and it looked great to me. I was able to execute it immediately and show your desired result.
-scraggs99
(2,768 Views)
