Old NI 9263 module in latest cDAQ 9185 not functioning properly
I have got my hands on a new cDAQ 9185 chassis along with some modules. I also have a very old piece of NI 9263 in stock (probably 10-12 years old which was spare in other system). I wish to use that in the new cDAQ. Upon installing, I can locate the NI 9263 in MAX, but it is giving around 2 to 3 volts in each channel even without doing anything. I tried to generate random DC output, but it is not responding. For sine/ square/sawtooth waveform, the amplitude is not what is entered. Is it firmware issue or the module is not compatible anymore with newer chassis?
(775 Views)
Try doing a Self-Test on that module in NI MAX.
Have you tested it on another "old" cDAQ? Maybe the module has broken?
https://tmesystems.net/
(750 Views)
On self test, the module shows success. It was working in the older cDAQ.
(731 Views)
