Omega Pressure Transducer troubleshoot needed
Hi, I am new to Labview and NI-DAQ device. I want to connect an OMEGA differential pressure transducer on a small pipe tube and acquire a voltage signal through DAQ assistant. The pressure transducer was provided calibrated by the company. The pressure transducer has a linear voltage output 0-10 VDC and the pressure range is 0-2.5 KPa. This means to get corresponding pressure signal I simply have to multiply the voltage signal by 0.25. The pressure transducer has 3 wires; black, white and red. The transducer requires 24 VDC excitation and I have connected the black wire to the –ve and red wire to the +ve of the 24 VDC power supply. I have connected the white wire to pin #31 of NI USB-6211. Additionally I have also connected –ve of the power supply to pin# 32.
Now when I use the DAQ assistant to acquire a signal on my computer and use a multimeter on pins 31 and 32 the voltage values do not match. Please if you could tell me what I am doing wrong here.
Thank you
Ali
(3,673 Views)
Hello Ali,
It seems like you are configuring your application differential. In this case, I recommend you to configure your device in an (RSE) way, using the pin #28.
In the followed white paper you will find information on how to achieve this and also their differences, since as you mentioned you are starting this is a  good reference while working acquiring data.
Field Wiring and Noise Considerations for Analog Signals
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
(3,623 Views)
Thanks for sharing the reference paper. Its indeed useful for beginners, however as you said about configuring the device in RSE mode I tried that but it did not solve the problem. The voltage signal that I get in RSE is very unstable with high level of noise. Whereas the differential model gives a stable signal which only changes when the pressure on the higher end of the sensor changes. However it does not match with the voltage signal that I directly take from the pins (for other sensors that I am using besides this the signal matches perfectly). I am guessing the sensor is faulty and have contacted omega to get their advice.
(3,594 Views)
Have you posted your code?  I've recently worked with Differential vs. RSE with the DAQmx tools.  I found that the create channel vi required a "constant" be wired to the input terminal configuration terminal.  otherwise the vi would change to a "default" mode which I think is differential.
Gene
(3,588 Views)
