Open valve digitally
Ok, I am having trouble doing what I said I needed to do in the last post, Dennis can you help me out?
Message 11 of 15
(1,103 Views)
Do you want all of them to be the same state. In other words, all 8 on for a certain time and then all 8 off for a certain time? If that's the case, I wouldn't even use front panel controls. Just an array constant wired to the DAQ Assistant. Then a Delay function followed by another DAQ Assistant followed by another Delay.
Message 12 of 15
(1,099 Views)
This should work for my first experiment but I want to be able to hook up multiple valves and run them at different times, so I will need a time on and a time off for each one. Should I hvae the setup there you showed me but each one for a different channel?
Message 13 of 15
(1,096 Views)
Basically, yes.
Message 14 of 15
(1,092 Views)
Thanks for the replies - they are helpful.  I figure out my problem.  I am wiring global channel to physical channel but in fact all I need is the line constant.  I am attaching the screenshot of my vi here.
wkc
Message 15 of 15
(1,083 Views)
