Order a case structure with digital wave
I want to order a case structure with a digital square wave in the case selector and the program will be run automatically, instead of using a push button, I will like to show some examples.
(4,168 Views)
Case case structure will not take a boolean waveform.  It can take single boolean values.  So if you read your digital signal one bit at a time, you can use the case structure.
What exactly are you trying to accomplish here?
GCentral
(4,156 Views)
I want to execute a loop in 1 second then a second loop for 1 second and that's repeatedbefore pressing the button stops.
(4,145 Views)
