Oscilloscope without ELVIS
I want to build an oscilloscope without using ElVIS in order to modify the code as i want to my application , the signals will be taken by NI-myDAQ
(4,271 Views)
Hi E.Essam,
Do you have a particular question or issue you're running into? Here are some resources with getting started in DAQmx: https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page... I am assuming you want to read in an analog voltage on your device. If so, this is a resource that addresses that subject: https://www.ni.com/en/shop/data-acquisition-and-control/what-are-multifunction-io-devices/taking-a-m...
There are also some great analog input LabVIEW examples that can be found here in the Example Finder: Hardware Input and Output > DAQmx > Analog Input.
Also, you may find the myDAQ community useful: https://decibel.ni.com/content/community/academic/products_and_projects/mydaq.
Sunayna R.
Applications Engineering
(4,242 Views)
Hi Sunaenae,
Actually i have try to build a simple Oscilloscope vi that takes analog voltages from NI-myDAQ ,
these Voltage represent Transfomer Primary Line voltage and Secondary line Voltage and display the phase Shift of each voltage .
thank you , the links are helpful Smiley Happy
(4,234 Views)
Hi E.Essam,
I'm glad to hear that! Our website has tons of great resources if you ever need assistance with programming in LabVIEW or interfacing with hardware.
Sunayna R.
(4,228 Views)
