Output 2 different signals on two AO channels simultaneously
I have 2 different signals that need to be ouput on two different channels at the same time. I have been able to write a VI that outputs the signal on one channel, but I cannt figure out how to alter it to output on two channels. One other complication is that I am trying to output signals that are longer than the output buffer so I have to write to the buffer in segments.
I am using a PCI-6115 DAQ Card and Labview 7.1
(2,820 Views)
Hello S.
Below is attached a modified shipping example that writes a waveform to two AO channels and continues to update the buffer because the waveform is long.
Hope it answers your question.
(2,812 Views)
