Output task continuity
I have recently acquired a USB-6001 that will be used in a test fixture I am designing.
I am very experienced in LabVIEW, but mainly in instrument control, and not in DAQ devices.
Reading in data is fairly intuitive and simple, but I am having trouble understanding digital out tasks.
For instance...
I have a state diagram style test program (enum, while loop, and case structure). If in one step of the test, ie one case of my case structure, I want to set a digital output high, do I need to leave the task running for that output to stay high? Can I stop the output (using DAQmx Stop Task.vi) or even clear the task and have that output remain high? Is it more resource intensive if I keep that task open without clearing it? I will be changing that line later in the test, but should I keep the task open and running, or should I stop and/or clear the task?
I know, a lot of questions, but I'm trying to just cover my all my bases.
(4,427 Views)
Accepted by topic author bshover
Digital lines will stay asserted after the task is clear. Running a task requires memory but unless you have rigid memory specifications it's easier to just leave the task running. I hope that answers your questions.
-Jayk
RF R&D
(4,394 Views)
