Overflow of the device onboard memory: -200795
I am trying to write an array of data to an AO line. I get an overflow of the device onboard memory, error # -200795.
Following is the code that I am using:
// Configure DAC Clock and Trigger
DAQmxErrChk (DAQmxCfgSampClkTiming (DAC_taskHandle, "", 1000, DAQmx_Val_Falling, DAQmx_Val_ContSamps,8192));
DAQmxErrChk (DAQmxCfgDigEdgeStartTrig (DAC_taskHandle, "/Dev2/PFI1",DAQmx_Val_Falling));
DAQmxErrChk (DAQmxStartTask (DAC_taskHandle));
// Copy the outputarrayy data into the DAC_Data to be written: array size: 8192
Copy1D (outputarrayy, INDENTNUMDACPTS, DAC_Data);
// Write to the AO channel through DAC0 lines
DAQmxErrChk (DAQmxWriteAnalogF64 (DAC_taskHandle,8192, 0, 10.0, DAQmx_Val_GroupByChannel, DAC_Data, &written, NULL));
I noticed that in the DAQmxWriteAnalogF64 function, if I use number of samples per channel as 8190, I did not receive the error. Could somebody help me out with this please. Any suggestions would be helpful.
reards,
Dwivedi
(2,811 Views)
Hi Dwivedi,
Looks like you're starting to make some headway with your AI/AO application.  Unfortunately it appears that you're running into a few errors that are slowing you down.  I did a quick search for what this error is that you're getting:
From the Explain Error Help in LabVIEW:
"Error -200795 occurred at an unidentified location
Possible reason(s):
There was an overflow of the device onboard memory while performing a hardware timed non-buffered generation.
Write only one sample per channel between two consecutive sample clocks to avoid this condition."
Have you tried running the example for this operation found here:
C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog Out\Generate Voltage\Mult Volt Updates-Int Clk-Dig Start ?
The only thing that I can really see is that you may want to change the DAQmx_Val_ContSamps to DAQmx_Val_FiniteSamps if you are doing a finite operation.
See if you can get the examples to work, and then work from there to see what the differences are.
(2,798 Views)
