Overloaded Channels on NI PCI-4474 + accelerometer
Hi, I've a problem acquiring the acceleration data with my NI PCI-4474 connected with an accelerometer (the OS is OpenSuse 11.3).
The program always detect an overloaded channel on Dev\ai0
// DAQmx Read Code
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,1000,10.0,DAQmx_Val_GroupByScanNumber,data,1000,&read,NULL));
if ( overloadDetectionEnabled )
	DAQmxErrChk (DAQmxGetReadOverloadedChansExist(taskHandle,&overloaded));
if( read>0 ){ printf("Acquired %d samples. Total %d\r",read,totalRead+=read); for(int i=0; i< read; i++){ printf("%f\n", data[i]); } } if( overloaded ) { DAQmxErrChk (DAQmxGetReadOverloadedChans(taskHandle,overloadedChannels,1000)); printf("Overloaded channels: %s\n",overloadedChannels); }
Restarting the program or powering off the device seems not to solve.
What are the possible causes of this overloaded channel detection?
Do I have to reset the board or change the accelerometer?
(3,034 Views)
I've plugged off the cable connected to the accelerometer and also in this case the board detect an overloaded channel.
So I assume is not an accelerometer or cable problem.
Is my PCI-4474 broken?
Is there anyone who can help me?
(3,000 Views)
