PB with DC Voltage acquisition LV 8.5 + DAQ PCI 6221
I have a problem when I do an acquisition of my DC voltage, sometimes the tension indicate by labview increase at 10V (default I think), where as my DC voltage have not change (I verfiy with a multimeter).
I don't know why.
I put my VI  here if you want to see my parameters of the DAQ express...
Bye.
(2,951 Views)
Hi.
Could you check with Measurement & Automation Explorer if you have the same issue?
Thanks in advance for your feedback.
Romain D.
National Instruments France
(2,928 Views)
Yes I have the same problem...
I have change my input but it's the same thing, sometimes, I don't know why, the voltage is 10V and after few seconds it become normal...
I have change my parameters now I choose RSE mode and not differential mode, it's ok now with other mode.
Regards.
(2,926 Views)
