Now, this is weird. Sometimes, when I try to use the DAQ Solution wizard to test the analog inputs, it measures the selected input pin but displays a noisy signal. Well, that's fine, but when I test the analog inputs individually in MAX, I start getting error - 10401 (Occured at AI Group Config). Right after that, the noisy signal disappears and I either get the error 1007 or error 10401. I am pretty sure the drivers are fine because I've re-installed and tested them many times and they pass all the tests etc. I really don't understand what's going on with the analog inputs. I've checked the pin connections and they're fine also. Right now while testing the analog inputs I'm not connecting anything to the input pins of the card. I guess if it worked fine, it should atleast show a noisy signal or something of that sort.
