PCI 1200 System crash
Hello everybody,
I am using the card LAB PCI1200 and I have a problem.
My App work correctly for some minutes and then the card made a system crash. In Nidaq Control panel I got this error:
“board does not respond on this IRQ level”
From this time the LPT1 doesn't work too!
When I reboot the PC and I go in Hardware configuration this card has IRQ=20 or 21
I have many many computers that work with my application with no problems.
This problem start when I changed the Motherboard PC.
Do you have any Idea / solutions ?
Regards
Daniele
(3,022 Views)
The first thing I would recommend trying is to upgrade the BIOS on the computer.
If that doesn't work, what kind of computer is this on?  Also which DAQ driver version do you have installed, I would make sure you are running the latest version, or at the very least version 7.3.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(3,008 Views)
